Best cam for A4/Stock Converter
Old 08-01-2006, 01:11 PM
Terry Burger's Avatar
Default Best cam for A4/Stock Converter
Well, the time has come to modify another FBody. This one is a budget daily driver (2001 WS6 Salvage) and I don't want to spend much money on it. I'm trying to pick a cam that will work well with 3.23s/stock torque converter, yet still pick up 30rwhp on the top end. I'm leaning towards a simple LS6 cam. Any suggestions?
Thanks,
T
Old 08-01-2006, 02:50 PM
sprayjunkie's Avatar
Not sure the LS6 cam is what you want... not right for me though it was worth about 20 more HP.Go bigger!
Old 08-01-2006, 03:37 PM
I've run lots of cams, but always with a converter. Something like an "old man cam" might be perfect for me.
Old 08-01-2006, 03:50 PM
Joel_SS's Avatar
Something with a high LSA that can idle around 500 rpm so you are not standing on the breaks and killing your legs to keep it stopped.. Honestly aftermarket cams and stock converters should not go in the same sentence.
Old 08-01-2006, 03:59 PM
Rob
Rob's Avatar
Maybe a GT2-3 would fit. Its cheap and will give you a good boost up top.
Old 08-01-2006, 04:00 PM
I was thinking the GT2-3 would work well, I like the idea of LS6 valve springs. Anyone have a before/after done on a mostly stock auto?
Old 08-01-2006, 07:34 PM
nuzee's Avatar
I like the way that the CompCams 206/212 cam lowered the engine's powerband to better match the stock TC. Cam alone gained 3 mph in the 1/8, but netted only a 1 mph gain in the 1/4 traps. I then added 1.85 rockers and got 3 mph gains at the 1/8 and 1/4 mi traps. It is a 112 LSA with 2 degrees advance ground in. I retarded the cam 2 degrees when I installed it.
I recently switched back to the stock TC after running a TCI3500. I like the way this cam feels with the stock TC. Very torquey off-idle and it does help minimize the "dead spot" acceleration. I am running 3.42 gears. I would run 12.5s with high 1.8 60 fts with the stock TC. IIRC the 1/8 mi would be 8.0@89. With 3.23s, it should still be pretty good combo.
edit: The cam also works pretty good with stock manifolds too. I haven't gotten around to install my headers yet. All of the times I mention & in my sig are using the stock manifolds.
Old 08-01-2006, 09:31 PM
will82's Avatar
Location: Somewhere Between Mild Insanity and Complete Psychosis
Predator Z has a pretty good cam he recommended to me before, 372rwhp/386rwtq, peak at 5900rpm, shift at 6100rpm, 300 rwtrq by 2500rpm on his a4 'vette w/ stock converter, CAI, ported throttle body.
210/224, .555/.568 115+1 LSA
Comp XE Lobe: 210/224 115LSA 114ICL
Lobe design# intake: 3708
Lobe design# exhaust: 3715
115LSA
114ICL
Old 08-01-2006, 09:36 PM
will82's Avatar
By the way, I was determined to go down this road before, but everyone here screamed at me to ditch the stock converter.
It has finally sunk in.
I'm going to be getting a yank ss3200 2.1 STR. From what I've heard this one is very drivable and hardly a difference from stock at cruise, doesn't require 2000rpms or anything crazy like that to keep moving. I'm sure you could get a similar one from yank for your f-bod.
Do the research. It's hard to go fast with the stock converter. That's what pushed me over the edge and caused me to give in. Besides, unless you're willing to do the work yourself, converter swap should be cheaper than a cam swap. Plus later you will have a wider selection of cam choices.
Old 08-01-2006, 10:16 PM
You need a converter to go fast. This is just more of a budget project, so I don't want to spend the money or bother with the install. =)
I want to pickup around .3-.4ths and 3-4mph with whatever cam I do...
T
Old 08-01-2006, 11:23 PM
SSPEEDY's Avatar
Will a hotcam work well with the stock converter?
Old 08-02-2006, 02:45 AM
Public Enemy's Avatar
Get The TR 224/224 114 LSA .563 .563 Lift w/ comp 918 springs, ti retainers and stock length hardened pushrods.. it will cost around 800 dollars with the cam gaskets from there.. then get it tuned and open the rev limit to 6600rpm.
u can use the stock converter
Old 08-02-2006, 12:25 PM
eamador11's Avatar
224/230 .581.581 @114lsa
Old 08-02-2006, 12:36 PM
PREDATOR-Z's Avatar
Basicaly you need a cam that will not pull on the brakes because you had to raise idle speed.
LS6
My cam mentionned above
GT2-3
CheatTR cam
etc....
in all a cam with very low overlap that can idle at 600 rpm.
Old 08-02-2006, 12:40 PM
I'm actually OK with the idle speed @ say 800 ish / stock converter. I'm more worried about keeping close to stock power @ 1100ish-1700ish RPM, as I spend a lot of time in this range.
Old 08-02-2006, 12:43 PM
PREDATOR-Z's Avatar
I think a CheaTR cam will do you good. It has the most potential as mods increase.
Old 08-02-2006, 01:18 PM
Cheatin' Chad's Avatar
I'll second the TR224
Old 08-02-2006, 01:20 PM
I've got HP tuners so whatever I do tuning will be no problem...
Old 08-02-2006, 01:27 PM
dug
dug's Avatar
If youre worried about gas mileage get a m6. I didnt lose any gas milegae with the cam swap. Still over 20mpg in town and 30 highway.
Old 08-05-2006, 07:10 PM
Still trying to find the best cam for a stock converter A4/3.23s....
Quick Reply: Best cam for A4/Stock Converter
