Comp Cams 1.85 rockers
Old 08-01-2006, 01:51 PM
whitesmokels1's Avatar
Default Comp Cams 1.85 rockers
Hey guys, i just bought a set of Comp Cams 1.85 ratio roller rockers, guide plates and studs off ebay. I just want to know what else i will need to install these. Do I use my stock push rods and lifters? Will my springs be too weak, is it absolutely necessary to change to a stiffer spring? I posted this question before but didnt get much help.
Old 08-01-2006, 11:04 PM
Jorge Olmos's Avatar
Is every thing in your engine stock?
Old 08-02-2006, 06:13 PM
yes, i dont want to build a race car but would like nothing to fail due to not being strong enough
Old 08-02-2006, 08:34 PM
Ditmeion's Avatar
I believe the guide plates will destroy your stock pushrods, so you need to get some hardened ones...lifters should be fine with stock cam.
Old 08-02-2006, 10:00 PM
Yes Sir. You should get their push rods and their valve springs and retianers
I do remember when SLP sold their 1.85 rockers they required a valve spring upgrade
Old 08-03-2006, 12:34 AM
WhiteRhino's Avatar
At the very least get the new springs. Our stock springs are barely enough for the stock cam. If not, you'll almost certainly get valve float or worse.
Old 08-03-2006, 02:49 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Springs and pushrods. I would stick with the stock ratio though honestly.
