real quick question on springs
ok i just got my cam(Comp 224/224 .581/.581), springs (918's) and retainers in. will be installing them soon on my heads. will it be pretty straight forward? just take the old springs out drop the new ones in and everything will be ok?? just want to make i dont screw anything up.
Depending on mileage you may want to consider new valve guide seals. The new design includes the seat and the seal - easy install while you have the spring off.
Do the TDC method for springs.
Bring piston 1 to TDC (using a tool) change 1& 6 (both at TDC), rotate crank clockwise 90*, and continue the next 2 cylinders using the firing sequence.
http://www.ls1howto.com
This site has it all, read it well.
the heads are still off the motor, i havent assembled the motor yet. and i just got the heads back from the machine shop about 2 weeks ago, new valve guide seals were installed there. and they are factory heads. thanx
