missing after heads and cam
I just got done with head/cam on my ls1 and i have miss on it now....it is missing on all cylinders but there is no dead miss....does anyone know what might be the problem...i am running ngk tr6 plugs set at a .040 gap i know these plugs are one heat range colder....i also went with a 230/236 cam could my tune be a problem with a stock tune
thanks
Dustin
thanks
Dustin
After installing a cam, you usually get a tune. You will get misfires after a cam install. The tuner should be able to take care of all of that.
Why are you running TR6 plugs with just a heads and cam car? TR6's are usually used in N20 and forced induction set ups.
I would get a tune, and ask the tuner about your plugs. They might recommend going to TR55's gapped to .055.
My car is cammed and I run the TR55's at .055
I would check the basics. Check to make sure all the plug wires or on all the way, check to make sure all of the plugs have gap, check to see if all injectors are connected. last is there a SES light on?
