update...need more help
ok i changed all the plugs because the old ones were really fouled.....even after we held the revs around 4-5k for 30 seconds.....the car is DUMPING fuel....my fuel pressure is at 60psi....i used 99 injectors which are 26 lb's i believe (stock 98's are 28lbs i believe as well)....once you start the car the car sounds normal but shuts right off....i have my fans wired to a switch so both fans come on high when i turn them on....i was having an issue where i would have to play with the wires to get them on (never had time to fix them)....today when i tryed to start the car after the new plugs i would hear the fans come on then when the motor shut off them would turn off. is it possible i have a short or a exposed wire that would keep the car from running or make it dump fuel?
Originally Posted by ArcticZ28
How about explaining a bit, my friend. No one on this site learns how to fix things by doing "a few different things".
