What does it mean when the cam has 11x +x LSA?
Ex 114+4 = the intake centerline is on 110 with +4 degrees of advance ground into the cam(same as advancing the cam with an adjustable sproket). 114+0 or just 114 means the cam has no advance ground into it and the ICL will match the LSA. 112+2 would = 110ICL + 2 degrees of advance ground etc, etc. Check out the camshaft sticky above.
