Just put 50 miles on the MS4 cam/Rod bolts/K-member/motor mounts/Torque Arm :)
I didn't expect the cam to be THAT much meaner sounding than the MS3 . . . but DAYUM!!! Because I'm running 2 mufflers in series the interior noise didn't increase by much at all . . . but the outside note is just WICKED
Right after my mechanic started it up for the first time he called me right away to tell me it sounded like an old-school Big Block idling
I noticed a big difference in the part-throttle driving. A lot more low-end torque By the butt-o-meter I'd say it pulls a good 15-25 more ponies from 1300-3000 rpm's at part-throttle over the MS3. That's REEEEALLY NICE
I was pleasantly surprised to see that the MS3 tune I had running perfect actually worked almost spot-on for the MS4.
I might have to tweak one table in the idle and that would be it.
I haven't gone WOT yet but I'll report back once I get the alignment done and my lugs from Jegs (ARP wheel studs needed some special long tapered lugs that NOONE in South Florida carries ).
After I do a full tweak on the part-throttle and WOT, I'll dyno my set-up and post the motor numbers
The poly-eurethane motor mounts are rock solid. They increased interior vibration substantially but I happen to like it.
UMI'S K-member, Torque-Arm, and Driveshaft Loop are TOP quality pieces . . . the red undercarriage looks pretty sweet too
Originally Posted by AutomagicLS1
Sounds bad ***!! Congrats...just a matter of time till my poor LS1 gets a wake up call
You wanna talk about poor . . . my Woman wants Heads, Cam, and full bolt-ons on the Red WS6 and we'll probably put Turbos on the Silver WS6
When people say it never ends . . . they're understating things
so what do you suggest for the valvetrain upgrade for this ms4 cam?
i have a tr224/224, but i want to sell it and get a bigger cam.. and this ms4 has really got my attention...
I'm running Manley Valves with PP .650 lift dual springs.
I've been running the same Thunder Racing hardened pushrods for over 60K miles.
My Thunder pushrods have been through 4 cams and 2 motors.
Cold-start, hot-start, ANY-start is BETTER than the MS3 cam . . . which was a pleasant surprise
Originally Posted by n2o junkee
I was going to go w/ the ms4 but instead went w/ the tsp giant cam (248/252, 611/613, 114lsa. Does anyone know anyone or have even seen this cam in any car?
Originally Posted by BLK02TA
Do you have to have the pistons fly cut to run this cam?
Fly-cutting is not necessary if one has stock heads, TSP Stage I LS6 heads, or un-milled ported heads.
I wish my Harlan shift-light went higher than 7K rpm's
My light goes off almost 200 rpm's early, so for me to hit 7100 rpm's I need to wait a bit with the light on and, literally, play-it-by-ear with my motor.
My impressions UPDATE:
The MS4 shifts more violently than the MS3 did . . . I like dat
I know I said it before but that whistle of the intake is sweeeeeeeeeeet
Originally Posted by dvandentop
does this cam work with the patriot stage 2 ls6 heads without fly cutting?
Ask John, Jason, Zack etc. from TSP to verify.
Originally Posted by stangkiller2005
so people are saying that this cam is for more cubes... so wat do you guys think? you wouldnt recomend it for an ls1?
As I've stated numerous times in this thread and others like it, the MS4 acts better, is easier to idle, and makes more torque through the entire rpm than the MS3 did; remember, I've had both cams now (including the 231/237 )
