130k miles and turbo and heads.... Cam swap?
Old 08-15-2006, 11:18 AM
killerbeez's Avatar
Default 130k miles and turbo and heads.... Cam swap?
Hey I'm changing to the ls6 heads and intake as we speak, and with the heads off I'm so close to a cam swap so I'm toying with it. Problem is, I have 130k miles, and I plan to run the STS turbo I have @ 5psi with methanol injection too. I could just buy a forged short block and do the cam then so I can have a more boost ready motor, would that be a better idea and just stick with the heads, intake, and turbo for now?
thanks
Old 08-15-2006, 11:21 AM
adillhoff's Avatar
I say if you are already doing H/I/T you should go ahead and spend the extra money for a cam. You would pretty much have a fresh motor if you got the forged block and pistons. It really depends on your budget, but if you can afford it and really want to do it: go for it. You won't regret it.
Old 08-15-2006, 01:54 PM
killerbeez's Avatar
whoops what I meant to ask is is doing a cam swap right now possibly pushing it? I'm not gonna build a forged bottom end til next year. I'm just worried I'm pushing the limits of a 130 k motor by doing the cam now. should I wait til I do the forged bottom end for the cam, as I'm already going to be running ls6 heads and intake and a lightly boosted sts turbo.
Old 08-16-2006, 01:09 AM
killerbeez's Avatar
to the top, if I should order a cam I wanna do it like tomorrow
Old 08-16-2006, 01:42 AM
NassyVette's Avatar
Run a compression test, if the motor checks out replace the basic stuff and go for it. Lifters, LS2 timing set, ls6 oil pump, pushrods, springs, cam.
