cam ?
cam ?
..okay..
how does this sound?
TSP Magic stick 3
237/242 .603/.609 112 lsa
this is gunna be in a 04 gto with a 4000 stall converter and a tune..the springs and tune will be done..is there anyone that has any Piston valve contact with this cam? any input helps...the goal from this car is goin to be a n/a car but also a daily driver.. how does that cam sound?
TSP Magic stick 3
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by Rescue Ranger
BIg *** cam for a DD, but with a good tune it'll work. Man not to be a dick but if you searched a bit you'd know everything there is to know about this cam. There are hundreds of threads made about the MS3 alone. No PVC problems with the MS3.
Anyway if you have stock unmodified heads you *should* not have any Piston to Valve clearance problems. The only way you will know for sure is to check when installing...
