View Poll Results: How many times have you hit the rev limiter
1-10 times
209
37.12%
11-20 times
73
12.97%
21-30 times
35
6.22%
31-40 times
13
2.31%
41-50 times
5
0.89%
51-60 times
5
0.89%
i ve hit it so many times i cant count
159
28.24%
i ve never hit it
48
8.53%
my motor is indestructable
33
5.86%
Multiple Choice Poll. Voters: 563. You may not vote on this poll
How many times have you bounced off the revlimiter?
Old 08-24-2006, 02:36 PM
just1news6's Avatar
Default How many times have you bounced off the revlimiter?
just curious how many times people have bounced off the revlimiters in ls1 cars and never broken anything, and if you did break something doing this what was it?
just1news6 is offline
Old 08-24-2006, 02:52 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
How many threads do you need?
orangeapeel is offline
Old 08-24-2006, 03:16 PM
00transamnh's Avatar
well i bounced off the rev limiter one time right before i replaced my cam... when i pulled out my pushrods 3 were bent
i didnt own the car when it was new so i dont know if the previous owner had anything to do with it
00transamnh is offline
Old 08-24-2006, 03:22 PM
Zger's Avatar
I never kept track. This thread is kinda pointless.
Zger is offline
Old 08-24-2006, 03:24 PM
SLVR_99-Z's Avatar
i thought the rev limiter was in place so you don't over rev and break something?
SLVR_99-Z is offline
Old 08-24-2006, 03:31 PM
mwill15's Avatar
I've bounced my rev limiter a lot. And, it's set at 6,900 rpm. I wouldn't worry too much about hitting the stock one.
mwill15 is offline
Old 08-24-2006, 03:56 PM
Jabroni's Avatar
Hit it a couple of times but never mechanically overrevved it.
SLVR_99-Z...the rev limiter will not save you if you mechanically overev. What I mean is causing the engine to spin higher than redline by forcing it to do so via the drivetrain. For example, shifting 3-2 on the track/street at the top of the tach and forcing the engine to overev too high. This isn't like just slamming the gas in neutral and bouncing off the limiter. That'll save you a bit in that instance but in real life a mechanical overrev will never be helped by your limiter in the computer.
Jabroni is offline
Old 08-24-2006, 04:35 PM
Bob25thTA's Avatar
Usually in first gear, Autocrossing.
Bob25thTA is offline
Old 08-24-2006, 06:13 PM
funnelone's Avatar
When I first put 4.10's in I was on the damn thing all the time in 1st gear. It almost seemed like the tach was alittle behind. Now that I am used to them I never hit it anymore.
funnelone is offline
Old 08-24-2006, 06:39 PM
gillbot's Avatar
I bang the rev limiter more than a worn out screen door. (No, that's not what I was gonna put! )
I was having some shift point issues for a while and I was hitting it bad and often on the 1-2 and 2-3 shifts. I finally got them dialed in though so I only hit it when I spin really bad.
gillbot is offline
Old 08-24-2006, 08:25 PM
Slo_240sx's Avatar
I hit mine ALOT. I dont have a working tach, stupid *** me. I paid for it by rebuilding my engine due to a spun rod bearing. I dont know it thats what caused it or the fact its a 98 block.
Slo_240sx is offline
Old 08-24-2006, 09:56 PM
ArrestMeRed99Z28's Avatar
I missed a shift after taking my car out of the garage for the winter, and broke a pushrod completely in half, never seen that done before, good thing the stock push rods are so crappy or else I would have probably broken a valve.
ArrestMeRed99Z28 is offline
Old 08-24-2006, 11:56 PM
FstBlkz28's Avatar
I've hit the rev limiter twice in my car. Once before the cam, once after ... both times though the clutch was thrown in and I was off the gas before it actually "bounced" ... so I've never really bounced it off the limiter.
FstBlkz28 is offline
Old 08-25-2006, 12:54 AM
Ubergeist's Avatar
Hit it once, didn't realize how slow this tach was.
Ubergeist is offline
Old 08-25-2006, 10:06 AM
blackls6's Avatar
Are stock rpms gauges not as accuarate as say an aftermarket one.
blackls6 is offline
Old 08-25-2006, 12:36 PM
FstBlkz28's Avatar
No, there is definitely some lag in the stock one. My shift light goes off in 1st gear and 2nd gear a few hundred rpm before the stock tach says its doing 6300 or whatever I've got my light set to go off at.
Old 08-25-2006, 12:59 PM
OneMeanZ's Avatar
Same here. My tach seems slower, especially when I hook at the track. It's off about 700rpms actually. It sucks
OneMeanZ is offline
Old 08-25-2006, 04:02 PM
2 SSlow's Avatar
my tach is extremely slow. I have hit my limiter probably a couple hundred times. ****, i hit is last night, and today, thats what its there for. I just got my clutch in, and didn't realize how slow the tach is.
2 SSlow is offline
Old 08-25-2006, 04:10 PM
Studytime's Avatar
I hit the rev limiter EVERY time I launch my car at the track.
Revlimiter a.k.a. "factory 2-step"
Ben T.
Studytime is offline
Old 08-25-2006, 05:49 PM
HeapaShifter's Avatar
I've hit mine many times. The stock tach really lags behind. I'd guess about 400 rpms behind what the engine is turning.
HeapaShifter is offline
