Changing Valve Springs in F-Body
Any usefull tips, special tools? I know More perf has a trick tool, but Im on a tight budjet.I have access to J-tools, is there an F-body specific tool? Any help greatly appreciated... Thanks
when i did the cam swap i got one of those leverage type compressors from autozone and it was a bitch, thankfully it bent and i had to get a new one so when i went back i seen the over head jaw style and it worked much better and was only a couple more bucks.
What is the Larry tool? Any one in south FL got one I can Borrow? How much is the crane tool?Do they both work with regular and beehive springs? Thanks guys!!!!!
Originally Posted by luv2spd
I'm partial to the crane tool. It works awesome and it compressess both the intake and exhaust at the same time.
[QUOTE=777]Overhead jaw tool did not work for me. It just pulled the spring up off the seat instead of pushing the retainer down.[/QUOTE
I used one of those on my LT1, just lightly(small hammer wrench)tap on the top of it a time or two as it first starts to compress the spring.And the retainer will fall down off the locks and you can continue to compress it then. I think this style compressor was my favorite. I had to use a lever type one to put my dual springs on my current car though it wasn't bad but then again the motor was out of the car this time
I use the tim tool. It's basically the same as the larry tool. The tim valve spring compressor can be found in the tool section of this site. He has a long thread going there. I'm not sure about the larry tool.
