One simple cam question
ya...if you are under a budget, i would go with comp's 918 and stock retainers. You will be good up to six hundred lift. Pushrods are also recommended since it doesnt take much to bend the stock rods. "cheap insurance"
Location: Somewhere Between Mild Insanity and Complete Psychosis
COMPCAMS makes a 206/214 and a 208/216 with .500/.500 lift. These would work with all stock valvetrain, they do not come with a flame suit however.
Originally Posted by Hada68GTO
How about the stock retainers? ARe they sufficient for 918's? My lift would be .581 Thanks
Originally Posted by Beasst8
Stock cam is what I would limit that to.
I would at a MINIMUM change the valve springs with ANY cam I installed.
Thanks for the anwers. I'm really did not want to instal a cam with stock valvetrain. That become on a talk with a friend who did on an LT1, just a cc503 with out upgrading the vlavetrain, so we were wondering if it can be done on a Ls1 as weel.
I'm running the 02-04 Z06, GM #12565308, 204/218, .550/.550, 117.5 LSA with stock springs and pushrods in my 00 LS1 powered sandrail with no problems. I don't rev it very high. No need to in the dunes.
Does anybody makes a RV cam for an LS1? Something with improved low-rpm torque? In the dunes, torque is your friend.
