Daily Driven Cam?
Daily Driven Cam?
Dont mean to annoy you guys with a question that has probably been asked 1000s of times but search is down still.
This cam will be a daily driven cam, I do not want to lose any driveability being that it is my only car. I will have full bolt-ons, matched stall, and the cnc ported ls6 heads from tsp at the time of the intsall. Also I dont want to raise my rpms past 6300 or 6400 rpms. I have been hearing that stock 4l60e's dont like anything past 6000 rpms. I am just looking for more power under the curve without raising rpms much.
Will diablo sport work with heads and a mild cam or do i need hptuners
Well, you can't go wrong with a 224 cam. I'm sure that's what 90% of the responses will say. Also, I don't know anything about the Diablo, but you definitely will want a tune with an A4.
What rpms are you running that cam to. like I said before, I dont want to raise the rpms too much with a stock a4. And how much power can I expect out of a 224 cam and the ported ls6 heads?
get the 224/228@114 cam from AFR. perfect DDcam
What kind (specs?) of valve springs would you be running?
I was going to be running the stock set up, whatever it comes with. If it is worth it I will spend a little more and get 918 springs and the competition valves. i am not sure what the stock set up can handle.
Also, if you want to install something else at the same time, IMO titanium retainers would be a better investment than valves. But that's just my .02.
