SLP t-chain...
SLP t-chain...
has anyone ever had problems with the crank sprocket? I was working with my machinist today trying to degree the cam and the sprocket had a ton of play in it. I don't feel the sprocket should have that much play in it, my stock one didn't w/ almost 100K miles. The crank is new, the woodruff key is also new... entirely different motor than the one that came out of the car. I was able to twist it around and slide it off and on the crank snout with ease.
Needless to say, I'm not using it. Just curious if anyone else had a similar problem ever.
