Thank God....Did I dodge a bullet?
Old 09-02-2006, 02:33 PM
8banger's Avatar
Default Thank God....Did I dodge a bullet?
I was worried about my head gaskets, because I had .040 Cometics, which are great, but I also have a stock bottom end, 234/242 cam, and 853 heads. I read how some of the 99 heads had the notch, that can cause a leak with newer gaskets, and didn't know if I had the notch in mine. I had the heads off for a while but didn't have a chance to look until today, and guess what? That notch was there. I'm getting LS6 heads now, since I got mine pulled off, and stock gaskets. My question is, did I dodge a bullet by not running the notched 853's with Cometics?
Old 09-02-2006, 02:35 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Why an insane split on the cam? You have a retarded amount of nitrous?
Old 09-02-2006, 03:01 PM
8banger's Avatar
Not yet... , but it might be in the future. I just liked the way my old G5X2 performed and that had an 8 degree split, and it seems that a lot of the best performing cams have wide splits (G5X4, T-Rex...record holders). I can't go too overboard with spray in my ride because i still have a stock bottom end anway.
Old 09-02-2006, 04:39 PM
Studytime's Avatar
That's not the trend when you look at duration at numbers OTHER than .050" lift.
Have you ever read up on how well the 230/224 TR cam performs?
Ben T.
Old 09-02-2006, 04:41 PM
ninobrn99's Avatar
he's done a bit of research on this cam. the DCR is pretty nice. Good luck with the new heads.
Old 09-02-2006, 05:26 PM
GuitsBoy's Avatar
Worst thing that would have happened is that it leaks all over your headers and the engine bay smokes like mad. it would be pretty evident.
Old 09-03-2006, 09:30 AM
8banger's Avatar
Ben T.
Not the trend? I'm not following you here. What about the TR230, not a good cam for what I want, doesn't make as much horsepower and also not a great spray cam. What's your point about numbers OTHER than .050" lift, like I don't realize there's more to a cam?
Old 09-03-2006, 09:31 AM
8banger's Avatar
Nino, when's the motor going in?
Old 09-03-2006, 01:43 PM
ninobrn99's Avatar
already done i blew the slave cylinder...again, so ive gotta replace that tomorrow
