Timing Chain Set
Old 09-04-2006, 11:29 PM
ricksvt's Avatar
Default Timing Chain Set
I am wanting to upgrade my timing chain set. I plan on putting a Kenne Bell on my project 67 LS1, so I would like a descent one. What about the oil pump too, whats the good thing to do on that?
Thanks guys, I dont know crap about this stuff
Rick
Old 09-04-2006, 11:31 PM
moeZ28's Avatar
Rollmaster double roller timing set. I have this and i am very happy with it.
Old 09-04-2006, 11:35 PM
ricksvt's Avatar
Do I need to worry if its adjustable and balanced, treat me like the newb I am to these things
Thanks
Rick
Old 09-04-2006, 11:55 PM
michael402z06's Avatar
Thanks
Rick
no, you don't need to worry about that stuff. all you need to get is a rollmaster double roller and an ls6 ported and shimmed oil pump. they aren't expensive at all.
Old 09-05-2006, 12:16 AM
ricksvt's Avatar
Best place to grab both of those?
Thanks
Old 09-05-2006, 12:21 AM
http://www.sdpc2000.com/catalog/2776...d-Oil-Pump.htm
http://www.sdpc2000.com/catalog/2267...on-Bearing.htm
Old 09-05-2006, 08:16 AM
ricksvt's Avatar
Thanks for the info on this.
Rick
Old 09-05-2006, 09:34 AM
slammedchevy's Avatar
i heard the ls2 timming chain is good
Old 09-05-2006, 10:29 AM
Cop Car's Avatar
LS2 timing chain with 2 new sprockets $45 from GMpartsdirect.com
TSP ported LS6 pump $140 from texas-speed.com
several benifits for that combo. 1 cheap. 2 works. 3 lots of high rpm guys are using this stuff so its proven.
do a search for LS2 timing chain if you want to know why you should save tons of money over a double roller
Old 09-06-2006, 01:49 AM
ricksvt's Avatar
This true, the LS2 Chain is better?
Rick
Old 09-06-2006, 03:19 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Rick
You really don't need the retarded insurance a double row allows. I would do the LS2 chain. I have a double roller in both cars however. It is a pain in the *** you really don't want to mess with in most cases. Cam swap is a little more time consuming with it in some cases. You have to shim for it as well. Sometimes it doesnt clear the timing cover too. I think that is the one they use on the C5-R motor. If it is good enough for that race car then it is good enough for your blower setup most likely.
Old 09-06-2006, 06:32 AM
JG853's Avatar
I have a JWISS in my Z06.
1996 Grand Sport
2002 LG Z06
2007 Z06 ordered but not yet delivered
