View Poll Results: MS4 OR TREX
MS4
157
58.80%
TREX
110
41.20%
Voters: 267. You may not vote on this poll
MS4 VS Trex
Old 09-06-2006, 10:42 PM
LastHawk02's Avatar
Default MS4 VS Trex
i barely drive the car so what u think would be better have basic bolt ons just gonna go with a cam now probally head a lil later on... its a m6
Old 09-06-2006, 11:27 PM
SVT THIS's Avatar
MS3 with heads vs TRex with heads: https://ls1tech.com/forums/showthrea...light=ms3+trex
Trex v. MS3 v. F15 v. G5X3: https://ls1tech.com/forums/showthrea...light=ms3+trex
TRex vs. MS3 vs. G5X3: https://ls1tech.com/forums/showthrea...light=ms3+trex
MS3 vs. TRex: https://ls1tech.com/forums/showthrea...light=ms3+trex
TRex vs. MS3: https://ls1tech.com/forums/showthrea...light=ms3+trex
Those are a few threads I got from a quick search. The MS4 is a lot like the MS3 with more low end. Most will probably say to go with the MS4 for the low end grunt advantage. The TRex has been proven again and again. Either way you'll have a sick car.
Old 09-06-2006, 11:28 PM
SSilverSSurfer's Avatar
i dont consider them even comparable, the TREX is just plain nasty
Old 09-06-2006, 11:34 PM
jermzz's Avatar
I put an ms4 in a car last sunday. Man it sounded nasty. AND the car had cats.
I vote ms4
Old 09-07-2006, 08:20 AM
Photochop's Avatar
The trex will probably not be quite as streetable unless you have an excellent tune.
It's big...however I know of a couple local M6 guys with bigger cams than the trex that daily drive their cars.
My cam is basically a trex...same duration and lsa but a little more lift. But I'm auto with a big convertor and 3.73s. The convertor flashes just shy of 4K rpm, from flash up it pulls like a freight train to 7K rpm.
With a 6 speed you'll want at least a 3.73 gear, preferrably a 4.10 You can probably run the MS4 with stock 3.42s without much trouble due to the increased lowend performance of that cam. You may not need to take that cam much past 6500rpm to make peak power either with the stock heads.
I voted trex cuz I'm biased
If you don't have or want to do gears then go with the MS4.
Old 09-07-2006, 11:07 AM
N4cer's Avatar
Will the MS4 clear on stock heads without flycutting?
Old 09-07-2006, 12:57 PM
anotherZfan's Avatar
same with the trex ,will it clear with the stock heads....no machining done...i understand check ptv...but who has done it
Old 09-07-2006, 01:00 PM
N4cer's Avatar
People on here act like nobody has put them on a stock bottom end with stock valvetrain on LS1 or LS6 heads. "Check clearance". Okay, yeah. Lemme buy all this crap, THEN see if it fits. Sure.
Old 09-07-2006, 01:10 PM
Photochop's Avatar
Both cams were designed to be true 'cam only' cams, thus not having to flycut the pistons to get them to fit.
My 'trex' fit fine without flycutting the pistons using the stock bottom end in my car with the tsp/prc stage 1 ls6 heads that are not milled.
Old 09-07-2006, 01:17 PM
LS1IMPULSE's Avatar
i think most of them would see if it fits and flycut if not, i guess if flycutting is out of the queston then you should go with somthign that you can be sure will fit.
Old 09-07-2006, 04:12 PM
SVT THIS's Avatar
Both those cams will fit with stock valved heads or ETP or Trickflow heads.
Old 09-07-2006, 05:07 PM
99 black ss sj's Avatar
i vote for the ms4 cuz i just got it installed by jermzz and it sounds badass when it idles
Old 09-07-2006, 05:24 PM
import slayer's Avatar
the rex produces more power
Old 09-07-2006, 05:48 PM
N4cer's Avatar
That's pretty vague.
You mean peak hp?
Or more power under the curve?
Old 09-08-2006, 12:04 AM
sciff5's Avatar
My car will prob be anywhere from 2300-2500lbs so the trex sounds like a better option for me as I'm looking for a lot of topend and I dont have much car to lug around, if I had a 3600lb fbody though I would prob get the ms4
sounds like the trex has more top end and the ms4 creates more mid range power.
Old 09-08-2006, 09:54 AM
bjamick's Avatar
i voted ms4 bc those things are sick and power band starts at 2300 rpm t-rex cant hang with that.
Old 09-08-2006, 10:05 AM
n2o
n2o's Avatar
It depends on what the guy wants. The T-Rex is more of a proven drag racing cam. I'm sure the MS4 will do good. But the guy did say that he did not drive his car much anymore. I would assume that meant that he is going to be interested in taking it to the strip. Based on this information I would say T-Rex.
Old 09-08-2006, 11:37 AM
Photochop's Avatar
It all depends on the goals for the car. The MS4 is a new style cam that creates more mid range power and torque which is going to be more 'street friendly'. The trex is definitely more of a strip-oriented cam.
Old 09-08-2006, 03:57 PM
stealthair's Avatar
MS4 fits fine without flycutting, on non milled heads
Old 09-08-2006, 05:35 PM
I thought that the trex did to
Quick Reply: MS4 VS Trex
