LS6 Conversion and now no Oil Pressure
I just finished installing my Ls6 Conversion Kit from summit. I also put a Crane double roller timing chain in scince i was taking the cam out. Well I finished the install and when i finally went to start it after getting the engine all ready to be started it had no oil pressure at an idle. when i held the motor at around 2000 rpms it would be around 45 to 50 psi and that is usually what i am at at an idle. I was thinking it had something to do with the oil pump when i had to shimm the back for it so it would fit in with the new chain. I heard somewhere that there is a special way that the oil pump must go in. like a special dept or something. or maybe the cam bearings are shot. the car has 74000 miles. I bought it with 68000 and i never really beat on it. I ran it at the track only one time but i dont know how the previous owner was so the bearing could be bad. Does anyone have any ideas.
