need HELP!!!
Old 09-09-2006, 06:20 PM
Emoney97ss's Avatar
Default need HELP!!!
last i was driving and was doing about 80 in 3rd and shifted back down to 2nd on accident and then it was only for a few seconds and then i pushed the clutch back in, it started to lose power so i turned it off.... so when i got off the freeway i turned it back on and it was fine... i got home and it start running rough around 800 rpms... then the service engine light came on... i went to autozone and the code was a p0303 miss firing number 3... so someone please help i'm a little scared to drive it now, cause i cleared the code and it came back at idle.... it runs fine when i'm gasing it but at idle it runs rough....
Old 09-09-2006, 08:16 PM
rwb
rwb's Avatar
Pull the plug on #3 and look to see if it has any damage.
Old 09-09-2006, 08:18 PM
Emoney97ss's Avatar
ok i'll do....
Old 09-09-2006, 11:17 PM
Emoney97ss's Avatar
thanks that was exactly it... i took it completely off then put it back on and then after running for a while it went away....
Old 09-10-2006, 09:00 AM
rwb
rwb's Avatar
If it comes back check your push rods to see if one is bent.
