cam choice for 408
Old 09-10-2006, 06:10 PM
SSPerformance's Avatar
Default cam choice for 408
Herese the run down, 12.5 to 1 with a set of ETP 245 heads , 90/90 setup posibly sheetmetal intake. Im still up in the air to go solid roller or stay hyd roller. car isent driven much so the sky is the limit on cam choice
Old 09-10-2006, 07:22 PM
dalejr8ls1's Avatar
T-rex or the MS4 would pair nicely with that setup. Just do a search and you will find several posts on it. There was one recently that had a poll so check that one out.
Old 09-10-2006, 07:44 PM
thoes are baby cams im curently runing something biger then that....im talk something in the 250 duration plus
Old 09-10-2006, 08:44 PM
Snapps's Avatar
See the sig for info
Old 09-10-2006, 08:53 PM
yea i thought about that cam...any times with it? dyno sheets?
Old 09-11-2006, 06:43 AM
Snapps's Avatar
Mustang dyno and partial tune I hit 499.4rwhp 468rwtrq with eddie current enabled leave an email address I can send the graph to ya.
Old 09-11-2006, 07:44 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Nice Snapps!
Mine is a stroker profile in an stock bottomed LS1 244/248.
Old 09-11-2006, 08:07 AM
GENIII's Avatar
Running a Comp 250/254 on a LSA of 110 ICL of 106 on my set up, not yet tuned still using a stock auto tune and idles at 900rpm when hot, drives very well. I originaly ran a 244/248 on a LSA 112. I would seriously look at diff gearing using a cam over 250 dur as I went with 4.11:1 on a four door Holden Commodore here in Australia.
Old 09-11-2006, 09:01 AM
kumar75150's Avatar
got a 253 261 .640ish lift cam on a 113lsa from Futral/Cam Motion for my 408
Old 09-11-2006, 09:26 AM
pewter 01 SS's Avatar
what kind of result did you get?? just bought one from them a little smaller. 250/257 640ish..
Old 09-11-2006, 09:27 AM
i would give allen at futral a call or erik koening at HPE.. their pretty busy all the time but they'll give you good advice.
Old 09-29-2006, 08:33 PM
what kinda power did the car make and is it a soild roller?
Old 09-30-2006, 01:30 AM
import slayer's Avatar
with that many cubes you can go a lot bigger than the rex and the ms4
Old 09-30-2006, 04:11 AM
getusum's Avatar
Look at your goals...is it N/A, or is it a no2 motor......I'm running a small cam 244/250 630/630 on a 114+2...Very streatable, built for n2o..and runs like scolded ape **** on motor.....You can have your cake and eat it too...lots of cam options....best of luck
Old 09-30-2006, 12:13 PM
the motor is gona be run N/A with some juice once and a while. motor was built for juice just dont wana spray it yet
Old 10-02-2006, 05:24 PM
Cam02ss's Avatar
i'll add my question to this post as well....i plan on doing a 408 also with the AFR 225's. what are the pros/cons to doing a solid roller vs. hyd. roller? im planning on spraying eventually and basically want to have a street brawler. i just had 4.30s put in the 12 bolt so thats the gear i'll be running. thanks
Old 10-03-2006, 03:36 AM
chrismcdaniel's Avatar
i also got a custom cam motion cam for my 408, slightly larger than that, but in the same ballpark 257/264 646/646 112
Old 10-03-2006, 09:13 PM
SOILD ROLLER?
Old 10-03-2006, 09:22 PM
SOILD ROLLER?
Nope.
Old 10-03-2006, 11:25 PM
getusum's Avatar
Chris, your a funny guy...lol Soild.....
Quick Reply: cam choice for 408
