Need Comp 224 cam #s
Old 09-13-2006, 01:16 AM
brians98ss's Avatar
Question Need Comp 224 cam #s
Can anyone with the Comp 224/224 .581 lift 114 LSA provide me with the advertised intake/exhaust durations @ .006 and ICL so that I can figure out my DCR?
TIA
Old 09-13-2006, 03:31 AM
jebcamaro's Avatar
I`d like to know as well. I`d like to know the 228r on a 114 too
Old 09-13-2006, 07:39 AM
PREDATOR-Z's Avatar
.006 # are 273 both sides, and that cam is usualy ground on a 114+4
The 228r is .006 # 277 and it is on a 112 (but I dunno the advance)
Old 09-13-2006, 09:45 AM
brians98ss's Avatar
Thanks.
Old 09-13-2006, 02:53 PM
ArrestMeRed99Z28's Avatar
I can not get the calculator in the advanced performance tech sticky to work for me. Can some one tell me what the DCR will be with stock 99 heads, head gaskets, and the 224/224 .581/.581 114(+4?) cam will be versus the stock 99 camaro cam? Thanks
Old 09-13-2006, 03:13 PM
PREDATOR-Z's Avatar
aproximately 8.1
Old 09-13-2006, 03:36 PM
jebcamaro's Avatar
Is 8.5 the highest DCR you want for running on 93 octane? Or can you go higher?
Old 09-13-2006, 05:51 PM
brians98ss's Avatar
I'm pretty sure 8.5 will be safe on 93 octane. You might be able to push 8.6, I don't know. Every car behaves differently. I've been trying to get a feel for what the limits are for 91 octane since I'm in CA.
From experience, I was running ~ 8.5 on 91 and maxed out at 26* of timing. Wouldn't take any more.
Brian
Old 09-13-2006, 10:51 PM
PREDATOR-Z's Avatar
2 things you want to improve while raising DCR.
1- quench, this is done by running a thinner gasket .030>.040 quench will reduce detonation potential.
2- Plugs, as SCR/DCR goes up using 1 range colder plug is recommended with a shorter gap (.040/.045)
Old 09-14-2006, 10:02 PM
thanks predator, what is the stock DCR? and what plugs do i need to run with the new 224 cam? should i just go for tr6s now incase i get the nitrous itch later?
