Whats the F#*K is draining my battery?!?!?!
Old 09-17-2006, 02:05 AM
ILLSMOKQ's Avatar
Default Whats the F#*K is draining my battery?!?!?!
ive replaced the altenator, and bought an optima red top battery and pulled all my wiring and still the battery drains dead after a day or so?!?! please help! jumping my car off all the time has got old quick!
thanx
Old 09-17-2006, 02:38 AM
Psychopjv's Avatar
you can check what is draining the battery by hooking a multimeter up and leaving the car off. see where the voltage is going.
Old 09-17-2006, 02:41 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Do you have a system in your car? If so I have found that some places will install an amp and not punch down the lead wire to the fuse box...They just loop it back into the amplifier power lead. Just a thought.
Old 09-17-2006, 04:43 AM
cantdrv65's Avatar
Post
With the key off....Take one lead off the battery and connect an DVM set on amps in series. make sure no interior lights or acessories are on, reading SHOULD be very close to zero. If any current is being pulled begin to pull fuses and reinstall until you find the at-fault circuit. Thats the best way to start....
Old 09-17-2006, 05:23 AM
Psychopjv's Avatar
Originally Posted by cantdrv65
With the key off....Take one lead off the battery and connect an DVM set on amps in series. make sure no interior lights are acessories are on, reading SHOULD be very close to zero. If any current is being pulled begin to pull fuses and reinstall until you find the at-fault circuit. Thats the best way to start....
thanks for clarifying my method more...
Old 09-17-2006, 05:25 AM
Boodyrider's Avatar
Battery is being drained by an electrical vampire...
Ok, maybe I ought to go to sleep now
Old 09-17-2006, 05:58 AM
DaddySS's Avatar
thanx
What aftermarket electrical pieces are in your car, theft deterrant, stereo, etc.?
When did the problem start?
Old 09-17-2006, 05:59 AM
N01SS's Avatar
this happened to me...not sure if its the same deal for you. Although the exciter wire that plugs into the alternator looked intact, the casing looked fine...but the actual wire was cut.
Old 09-17-2006, 08:05 PM
ILLSMOKQ's Avatar
i pulled all aftermarket wiring, sounds like a good idea with the volt meter! thanx!
Old 09-17-2006, 08:53 PM
Order 66's Avatar
Check to see if your glove box light goes off when you close it. Sounds dumb, but thats what happened to me. The light knocked out of its holder and never went off and drained the battery.
Old 09-17-2006, 10:34 PM
Raleigh TA's Avatar
Ditto for me. Hard to diagnose since most of us don't work on our cars in the dark. Simple problem causing a big PITA.
