Low oil pressure.
Low oil pressure.
I know this subject has been brought up quite a bit of times. But, all the post I see people never see to agree.
So, here is my issue. I recently just swapped my LS1 intake to an LS6 intake manifold. The car seems to be running fine, but my oil pressure, when it is warmed up, it is idling around 25 - 30 psi. It was never that low before. It used to site maybe around 35 and closer to 40.
What could have possibly be different from before the intake manifold swap to now?
Originally Posted by DaddySS
Is the idle rpm the same? Did you check to make sure no damage to the sender before you put the new manifold on? Is the coolant temp the same as before?
Well, all the sensors were the same. And, the oil sensor unit was the same also. I made sure to be very careful about not damaging none of the sensors, especially the oil sending unit.
Regardless, I think I'm still going to swap out the oil sending unit just incase. It's better to replace a $30 sensor, than worrying the my engine goes.
Oh yeah, the coolant temp is the same, too.
