cleaning new parts?
cleaning new parts?
is it nessacery to clean brand new tsp ported heads? like hot tank etc or just stick them in..
also what to use to clean out and inside of new camshaft? brakeleen, gas, lots of paper towels?
I've done it two ways. You can use brake cleaner or you can get a bucket of soapy warm clean water and a gentle brush and scrub everything down well in the oiling holes and everything. Then rinse with clean water, and then blow dry with an air gun. You want to get the machine oil off and out of the camshaft and all the little recesses in the camshaft and heads. Not to mention you can't have anything too clean Eithor is an acceptable way, just keep in mind that eithor way you want to lubricate everything liberally with 30 weight engine oil while assembling.
thanks. i did end up cleaning the cam with brakeleen and used laquor thinner to soak the lifters in, i got some powerwasher hd degreaser so today after its light out ill wash the heads.
