Offset cam bushings to change ICL?
Old 09-18-2006, 06:08 PM
Studytime's Avatar
Default Offset cam bushings to change ICL?
Has anyone here used offset cam bushings to change their ICL? I'm currently at +4 or +2 (waiting on cam doctor specs), and want to install my cam at +0. I already have a new LS6 chain, so I was hoping to get by with some offset cam bushings.
Also, is the use of these bushings safe?
Ben T.
Old 09-18-2006, 11:28 PM
Studytime's Avatar
I guess most just install their cam dot-to-dot and don't advance/retard the ICL of the cam different than how it was ground.
TTT
Ben T.
Old 09-19-2006, 08:13 AM
GuitsBoy's Avatar
Not sure what you mean by cam bushings. I guess you mean the pin thats pressed in the front of the cam? I would imaging that to work fairly well, assuming you dont go too big (less metal at teh seam). Otherwise you can dial in your cam without an adjustable timing set .
Old 09-19-2006, 08:26 AM
matt94z's Avatar
I used offset bushings for my new LT1 motor that is being built. I think I got them from Jegs. You have to drill the timing gear and push the bushing in. I bought two packs (one pack are odd degrees and the other are even) got my cam within .5". I'm sure it would be the same for a LS1. You should always degree cams anyway....
Old 09-19-2006, 08:34 AM
GuitsBoy's Avatar
Okay, drilling the timing gear and pushing an offset bushing in makes more sense. I thought it would look more like the offset head pins.
Quick Reply: Offset cam bushings to change ICL?
