anyone know wtf this is in my pickup?
Old 09-21-2006, 01:05 AM
offaxis's Avatar
Default anyone know wtf this is in my pickup?
I noticed my oil pressure wasnt as high as before and actually was falling off alittle when I would make a pass. It wouldnt go too low but It would drop so I had my mechanic pull the pan and this is what he found.
Any guesses and I dont have any red silcone on this motor
thanks
Old 09-21-2006, 01:37 AM
rollinna65's Avatar
Looks kind of like a piece of the rubber gm used in the gaskets.
Old 09-21-2006, 01:43 AM
offaxis's Avatar
pretty decent size tooo. I wonder where it came from.
Old 09-21-2006, 04:52 AM
Race your car!
JL ws-6's Avatar
when you did the cam install, did you put any rtv anywhere in the motor? I know alot of people do at the bottome of teh cam cover dor added sealing, maybe it's a piece from that?
Hopefully it's nothing major....
Old 09-21-2006, 09:34 AM
offaxis's Avatar
I did but I only used black rtv and just a dab in the corners
Old 09-21-2006, 09:44 AM
GregWS6&z28's Avatar
I was thinking RTV gasket maker too
Old 09-21-2006, 09:53 AM
N4cer's Avatar
Is it silicone for sure? Looks like paper to me. Like someone put an oil additive in your oil, and the cap liner might've fallen in.
Old 09-22-2006, 03:35 PM
silverbandit0996's Avatar
very true i think its some kind of paper liner out of a bottle.
Old 09-22-2006, 03:40 PM
offaxis's Avatar
Im still not sure but it feels like rubber. I changed the pickup and all is fine now.
Old 09-22-2006, 04:30 PM
Stroker2112's Avatar
Could it have been clay from a PTV excercise?....
Old 09-22-2006, 05:41 PM
nukeemall454's Avatar
bubble gum man J/k
Old 09-22-2006, 05:54 PM
sroach20's Avatar
condom?
Old 09-22-2006, 07:15 PM
GuitsBoy's Avatar
Looks like the orange silicone on the aluminum timing cover and waterpump gaskets for the 1999+ motors. Theres also a rubber hourglass gasket on the back of the cam retaining plate to connect the oil galleys. And theres orange threadlocker on the back of the flange of the crank bolt that might fall off, but a silicon gasket is my first guess. From the zise and radius of it, i think it most likely pulled off the front timing cover gasket and dropped into the pan.
Old 09-22-2006, 07:36 PM
offaxis's Avatar
I am sure someone here has it right. Might be gum or a condom but I am not sure.It is about 1/4 inch thick..
Thanks for the input
Old 09-22-2006, 08:49 PM
Beasst8's Avatar
This is exactly what I was thinking!!!
Old 09-22-2006, 09:00 PM
ArcticZ28's Avatar
What kind of condom's do you use, man??
Old 09-23-2006, 01:50 AM
eallanboggs's Avatar
The orange locktite from the crank bolt wouldn't get inside of the engine, but it could from the rocker bolts. The chance of either one happening seems pretty remote. Could it come from the cam plate gasket? Maybe, but unlikely it would come from the water pump as that is the coolant system not the oil gallery. Orange RTV? Could be, but the gaskets on these engines are so good it's not really needed. You are supposed to put a tiny amount of RTV on the edges of the front timing cover and on the oil pump spacer when you install a double row timing set, but the amount used is so small it doesn't seem likely that there would be that much excess left over to block the oil pickup screen. Guess you'll have to call Columbo.
