What gaskets are needed?
Hi everyone,
I'm getting ready to put my motor back together and I'm curious as to what gaskets I need?
The only gaskets I can think of are the oil pan gasket, head gaskets(have those already), water pump gasket, and exhaust mani/header gaskets(already have). What else am I missing here? Any help would be much appreciated!
Oil pan gasket
Front cover gasket
Rear Cover gasket
Front main seal
Rear main seal
Oil pump o-ring
Head gaskets
Coolant crossover seals, if you are not using LS6 coolant tubes
Water pump gaskets
Valve stem seals
Valley cover gasket(reusable)
Header gaskets(reusable)
Valve cover gaskets(reusable)
Front cover gasket
Rear Cover gasket
Front main seal
Rear main seal
Oil pump o-ring
Head gaskets
Water pump gaskets
Valve stem seals
Originally Posted by Ferocity02
Oil pan gasket
Front cover gasket
Rear Cover gasket
Front main seal
Rear main seal
Oil pump o-ring
Head gaskets
Water pump gaskets
Valve stem seals
Front cover gasket
Rear Cover gasket
Front main seal
Rear main seal
Oil pump o-ring
Head gaskets
Water pump gaskets
Valve stem seals
Originally Posted by lilbuddy1587
I have a FAST 90/90, so would my coolant tubes have been changed over when it was installed?
