Port and Polished 6.0 heads
I recently installed a set of 6.0 lq9 heads on my 2001 TA I also had them port and polished. I have heard that they lower the compression and there is little or no gain. Would I see a gain since I port and polished them?
What would you go with Ben? Im looking for a hopefully a solid 15-20 hp if thats even possible with the 241's. What would I have to do to get this out of the 241's?
Originally Posted by headed-ws6
If I can get the specs to get a stage 3 p & p on my 241's I would sell the Lq9 heads.
Both, but starting with something that isn't setup for your app and then trying to make it work is never a good manner of finding hp. If I were you, I'd start by spec'ing out the cam I wanted first. Then, I'd figure out which heads flowed well where you needed it the most.
