maximum 6.0L stroker
Old 09-23-2006, 09:16 AM
sslow2000's Avatar
Default maximum 6.0L stroker
I just want to know what's the biggest (mostly reliable) stroker that can be made from a 6.0L iron block and what bore and stroke is necessary to make it. I heard something about a 414, 423.... etc. What's the most you can reliably bore out one of these blocks? thanks
Old 09-23-2006, 09:55 AM
PREDATOR-Z's Avatar
Old 09-23-2006, 12:00 PM
sslow2000's Avatar
ok well, screw reliability...
what are some combinations bigger than a 408 that are commonly made? I heard something about someone making a 454... but that might have been an aftermarket block...
Old 09-23-2006, 01:17 PM
PREDATOR-Z's Avatar
This will give an idea
http://www.cartek.net/parts/engines/...eriesmain.html
Old 09-23-2006, 01:38 PM
2001bluerata's Avatar
MTI has a LS2 427 stroker
Old 09-23-2006, 01:56 PM
silver01z06's Avatar
a ls2 427 is probably a resleeved block
Old 09-23-2006, 02:05 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Out of an iron 6L block you can get a 418 which I have 4.100 stroke 4.030 bore or you can go to 4.100 stroke and 4.040 bore which is a 422 I believe. I have heard of people getting .060 overbore but I wouldnt push it that far. The 4.125 stroke crank that I believe Lunati makes would be nice but it would cause many clearance problems. With the longer stroke crank the piston goes too far down and you get BAD piston rock at BDC. With my 4.100 I am having problems with piston skirt wear. Bould a 408 its reliable and there is a reason why there are hunderds of them out there.
Any 427 made with a 4" stroke which the MTI motor is has a 4.125 bore which is not possible without sleeving an iron block.
Old 09-23-2006, 09:00 PM
It is resleeved, nothing wrong w/ that?
Old 09-23-2006, 11:20 PM
sslow2000's Avatar
I was mainly asking about the iron 6.0 block not the aluminum ls2...
I wasn't aware that the iron blocks had sleeves? details please?
Old 09-24-2006, 12:37 AM
PREDATOR-Z's Avatar
Did that link not work for you?
It lists all the cubes available with part details.
Old 09-24-2006, 01:34 AM
SLED28's Avatar
I have done many 421 iron motors with 4.125 strokes and 4.030 bores. They are great motors, lots of HP and torque.
Old 09-24-2006, 10:24 AM
sslow2000's Avatar
no the website only had 2 iron block motors listed, the 408 and a 422. the rest were resleeved aluminum blocks... which isn't what I was asking about.
sled28: have you had any problems simliar to the wear experienced by 1slow01Z71? or any other issues with the 4.125 stroke? also, have you bored the iron block out more than 4.030? can they go larger than that? I know a previous poster said .060 over was a little much.
Old 09-24-2006, 10:53 AM
SLED28's Avatar
I haven't had problems no. When I go to a 4.125 stroke, I use a 6.200 rod so it ends up pushing the piston back up into the bore an extra .075" more then a 6.125 rod motor. Now the extra stroke is only .125" which is .0625 more up and down. We are putting back in .075, so minus the .0625 we're actually up in the bore .00625 more then a 4.00/6.125 stroke combo
I have gone .030,.040, & .060 over in iron blocks. I would recommend .030 or .040 for power adder motors, and 4.060 for N/A combo's.
Old 09-24-2006, 11:04 AM
PREDATOR-Z's Avatar
That is a nice way to cure some of the initial piston position ailments of bigger cubed motors.
Old 09-24-2006, 11:13 AM
SLED28's Avatar
Some combos I've had to bump up to 6.250 rods
Old 09-28-2006, 07:33 AM
Tennessee Auto's Avatar
Sled28 - What pistons have you been using on the 4.125 stroke 6.200 rod setups?
Thanks Scott
Old 09-28-2006, 12:43 PM
SLED28's Avatar
Ross pistons
Quick Reply: maximum 6.0L stroker
