AFR 205s milled 30 and 224/228-112 PTV
Old 09-23-2006, 08:59 PM
Chalky's Avatar
Default AFR 205s milled 30 and 224/228-112 PTV Clearance?
Does anyone know PTV clearances with 224/228 or 228/232 on 112 with AFR 205cc milled .030?
I was talking to Tony Momo about cams and he said 228/232 would be tight even on 112. I forgot to ask how tight.
Plans are for Cometic HG @ .040
Assuming piston deck clearance @ -.007.
Old 09-23-2006, 09:20 PM
Tom@SpeedInc's Avatar
which rocker arms will you use?
Old 09-23-2006, 09:23 PM
Chalky's Avatar
Stock, 1.7:1
Old 09-24-2006, 10:38 AM
ShevrolayZ28's Avatar
See my sig for mods. I opened her up pretty good last night for the first time and there was no catastrophic failure lol. (And the car is pretty quick now!) I did not measure P to V when I put it together so I don't have a number for you, but from what I've read, mine should be in the range of "acceptable" (.080" INT/0.100" ex). Keep in mind that I am running a 114+1 which should provide more clearance than a 112.
