Comp Cams XR281HR hard on valvetrain??
Old 09-25-2006, 01:14 AM
mvvette97's Avatar
Default Comp Cams XR281HR hard on valvetrain??
Is it the XR or the XER that is known to cause valvetrane noise and damage?
Old 09-25-2006, 02:13 AM
prplhaz's Avatar
I don't know about "valvetrain damage", and noise is the nature of the beast which can be minimized with proper pushrod length and valvetrain setup.....BUT Comps' XER line has the more radical valve opening and closing rates and would be considered "harder" on the springs.
Old 09-25-2006, 02:15 AM
mvvette97's Avatar
so is the XR a little more mild as far as the opening and closing?
Old 09-25-2006, 02:31 AM
prplhaz's Avatar
Yep, that's correct.
Old 09-25-2006, 08:19 AM
GuitsBoy's Avatar
I think youre referring to XE lobes (not XR). Yes those are more gentle on your valvetrain. The XE-R lobes are more agressive, but tehyre definately worth it. You can still get good springlife out of a set of dual springs and an XE-R cam.
Old 09-25-2006, 08:23 AM
PREDATOR-Z's Avatar
XE ramp rate variance 53
XE-R ramp rate variance 49
LSK ................ >>> 50
Cammotion (futral) >>>>50
Old 09-25-2006, 09:16 AM
mvvette97's Avatar
it says this for the cam...Competition Cams Comp XR281HR 228/230 571/573 112 Part number 54-428-11
Old 09-25-2006, 09:18 AM
stevewix's Avatar
go 54-446-11, i have it in my car and it's a bit lumpier than i'd like but a very preliminary tune yielded 413hp with simply a cam & headers
Quick Reply: Comp Cams XR281HR hard on valvetrain??
