Synthetic oil switch from regular at 50K
Old 09-26-2006, 09:55 AM
cold_surfer's Avatar
Default Synthetic oil switch from regular at 50K
I've been on a free oil change program at the dealer -- every 3K using regular oil since new. Since the warranty expired at 50K this spring, the dealer has posed bogus repair quotes and other scams (like quoting $150 to replace the battery because they saw OLD corrosion evidence -- but didn't notice a new GEL battery in there when refilling the oil - WTH?).
>> we doubt the dealer has used the exact same oil every change.
I want to switch to synthetic at 50K and change it myself now. Anyone think it's a bad idea? wear patterns? horror stories? risk of leaks at seals? I know I should have done it when still under warranty.. .
I drive the LS1 2002 TA pretty hard. This might make it better.
Old 09-26-2006, 02:35 PM
00454sscamaro's Avatar
you used non sythetic in an ls1? shame.. switch to sythetic , i beleive only the older motors with older style gaskets were the ones habing problems going to sythetic.
Old 09-26-2006, 03:14 PM
ChicagoTransAm's Avatar
Switch on over... This whole hupla about not being able to switch is bogus.. You can even go back and forth if you want...
Old 09-26-2006, 03:42 PM
getusum's Avatar
Not trying to steal the thread....I've got about 2500 on motor is sig....my builder says I can stick with cas gtx 10/30, or switch to synthetic...I was thinking of switching to cas synthetic blend.....any comments
Old 09-26-2006, 04:18 PM
N4cer's Avatar
Why blend? Just go full synthetic.
Old 09-27-2006, 07:57 AM
my brother was burning up gears in his race car in two races using convent. oils. He switched to synth and hasn't burnt a set in 2 seasons now.
I appreciate the input. Goodbye Dealer !!!!
Quick Reply: Synthetic oil switch from regular at 50K
