Cam experts come on in
So heres the deal buddy of mine wants to do a cam on a 98Z with 131K on it.
the engine has been very well maintained and runs great but ill be getting a new LS6 oil pump and new timing set. Were lookin to rev the motor no higher then 6400 and stall no higher then say around 3K. Right now the car has 3.42 gears full exhaust including LT's an SLP lid with bellows and a ported TB. He will probably be using the stock LS1 intake for the time being and stock pully. Already have a set of new 918 springs sitting around. His goal is a nice choppy idle kinda similar to my MS3 cam if possable just slightly less, with some decent torque and mid range and upper end power. We were thinkin about somthing similar to a 224 cam but the idle is pretty weak on those from what I've heard so open for suggestions. The car will also be getting a lower stat and a full dyno tune of course once we pick put a cam. Remember catch is the carstill has over 130K on it so cant go crazy here...
Just be sure to keep an eye on oil level. Oil starvation is going to be the number 1 killer for his motor. Higher average RPM and old piston rings are going to mean keeping a close eye on oil level to prevent spinning a bearing.
Ben T.
Ben T.
Originally Posted by b00sted
I don't think you'd need to spin the MS3 that high...I'm sure shifting before 650 will do just fine. If he's worried, get some rod bolts and go for it.
"Go big or go home" comes to mind.
Ben T.
Originally Posted by Studytime
I agree with this advice. Instead of installing a known handicap, get some better rodbolts and go for it!
Ben T.
Ben T.
Ben T.
Ben T.
Either way, what I posted above is just how I think. My 160k mile m6 z/28 did a 13.4 on street tires with just a lid on it. The car ran like a raped ape for the amount of miles on it. I had a th350 built and planned on running a 4000 stall and a 150 shot...And you know what? I bet the car would have absolutely loved it.
Miles shouldn't scare you if you know the maintence record. If it's been taken care of and maintained on time, you shouldn't have to worry. LS1s are remarkable motors as far as power delivery and reliability.
I say go for the MS3. I've seen that cam work. Double springs, hardened pushrods, and new retainers...Get the best dyno tune possible and your buddy will wonder why he ever thought about going with something else. PM "Matt D."...He ran the cam and can tell you all about it from first-hand experience. He drove that car everywhere and ran some impressive numbers for what it was.
Yeah but the problem is he is working on a $1900 budget and The MS3 needs to be spun to 6700+ to make the most of it I would know I take mine to 6800 and if I had an upgraded bottom end I would go to 7K+ if he wants to keep a shif point of 6400 or lower the MS3 is a bad choice havent you guys ever seen a dyno graph for this cam?
Originally Posted by HottLS1Z
Can anybody tell me more about this torquer cam? Anyone that has it?
There is a Torquer 1, 2, and 3 cam, check them all out.
