White smoke!?!
Old 09-28-2006, 03:50 PM
logo_craig's Avatar
Default White smoke!?!
me and my buddy raced last night and he told me that he saw some white smoke coming out of the exhaust...and i noticed the other day that i have some kinda fluid being spit out of the passenger exhaust, there is not much smoke coming out, its just every once in a while it will spit some out.....is this just condensation in the exhaust??
or do you think there is oil in my PCV system??
Old 09-28-2006, 05:49 PM
mmmchickenboy's Avatar
white smoke is usually coolant.
check and monitor the levels of your fluids to see if any of them go down over time.
Old 09-28-2006, 09:24 PM
rubber duck's Avatar
As a precautionary measure I'd go ahead and change your oil as soon as possible to see if there's any coolant in it. If there is you will be able to see it pretty easily since oil and coolant do not mix. Also check your oil fill cap to see if there is any white foam on it after you drive it. Usually white smoke means coolant is getting burnt, for me it meant a headgasket was on the way out. If the white smoke was pretty visible that's usually not a good sign.
Old 09-28-2006, 09:26 PM
staringback05's Avatar
headgasket geez
Old 09-28-2006, 09:34 PM
Sigforty's Avatar
Originally Posted by staringback05
headgasket geez
That sounds about right!
Old 09-29-2006, 01:33 AM
logo_craig's Avatar
well i dont see it that much, i really only see it if im at WOT or gettin' on it hard.
i hope its not a headgasket...
Old 09-29-2006, 03:27 AM
Silver Arrow's Avatar
had the same problem ... it was the headgasket
Old 09-29-2006, 05:30 AM
300bhp/ton's Avatar
Is it smoke or water vapour. They are very DIFFERENT.
Old 09-29-2006, 10:07 AM
logo_craig's Avatar
ok thanks guys for all the replys!
im gonna try to figure out what it is tonight.
Old 09-29-2006, 12:24 PM
black01_WS6's Avatar
I have the same problem going on now. I only see smoke at WOT. I have a set of ls6 heads that I am getting ready to ship out and get them worked over. I hope that it is only the head gasket in my case, as I am not made of money.
If coolent is getting in the oil will it look like oil in water? I am changing it this weekend.
Old 09-29-2006, 01:29 PM
Tootall's Avatar
or break fluid, if your master goes out and leaks into the break booster
Old 09-29-2006, 02:27 PM
logo_craig's Avatar
im not made of money either, im a broke *** college student!
