LS1 Fuel Injector O-Rings...Help
Old 09-28-2006, 08:33 PM
HEMIETR's Avatar
Default LS1 Fuel Injector O-Rings...Help
GM list price $75.37. Can get them thru Fred Beans or GMPartsdirect.com for around $50. Thats still crazy expensive. I searched and found others that had the same problem but no real solution. I don't want to go to Autozone and get o-rings that don't work. There has to be an o-ring that GM uses on other cars that will work. If someone knows for sure, I could use some help. Thanks in advance.
Old 09-28-2006, 09:51 PM
xssive's Avatar
You can get o-ring service kits from Napa. Even 5.0l ford injector service kits should work
Quick Reply: LS1 Fuel Injector O-Rings...Help
