TSP Terminator 200cc track results(11.2 @ 122)
Old 09-30-2006, 12:14 AM
7 Second Club
Phil99vette's Avatar
Default TSP Terminator 200cc track results(11.2 @ 122)
All the info is still coming in but....
2000 Trans-Am 6 speed
TSP Short Block
TSP Terminator 200cc heads
90/90
3620lbs
Custom cam
~400' DA
First pass out...
1.5x 60'
11.22 @ 122
A/F: 11.87:1
Timing: 26 degrees
Plugs: 7s gapped @ .035
Shift: 6900 -> should be 7400 with new rockers
The motor is setup for nitrous, we're trying to dial in the tune before we start spraying it.
Old 09-30-2006, 12:57 AM
Kent1's Avatar
Nice numbers indeed at the track. What are the specs of the custom carm if permissible? Did you flycut or not? Is your car an auto or 6 spd? I have the terminator heads and the MS3 cam with 90 intake/TB to be installed later. It is nice to know the terminator heads are performing at the track.
Old 09-30-2006, 01:27 AM
Patrick B's Avatar
Hey Phil is it a hydaulic or mechanical cam?
Old 09-30-2006, 08:30 AM
7 Second Club
big 230s small 240s ~.600 lift
Pistons are -2cc flycut
6 speed
Old 09-30-2006, 08:31 AM
7 Second Club
Hyd roller
Old 09-30-2006, 04:41 PM
Beast96Z's Avatar
Do you think there's gunna be any power at 7400 rpm's with a 230ish hydro cam? I would think that it would be petered out by 7k.
Old 09-30-2006, 05:07 PM
7 Second Club
Its not about having power, its maximizing the power available under the curve.
Old 09-30-2006, 05:15 PM
eric01ss's Avatar
so very true in all in the curve and up top!!
Old 09-30-2006, 10:03 PM
Beast96Z's Avatar
OK, but how is that gunna make reving the cam to 7400 more productive? If the cam peaks at 6500, holds peak a few hundred rpm's, then falls off by 68-6900 rpm's, how is pulling it to 7400 gunna be benificial? If you have to rev to 7400 to get the cam in a better spot on the rpm drop from shifts, then it seems that maybe a better camshaft selection would be in order. I'm not really all that worried about it, but more or less trying to figure out why you would want to ring a cam of that size out that far.
Old 09-30-2006, 10:24 PM
bad95killer's Avatar
Damn on nitrous tune & ran low 11's thats truly amazing & can't wait untill he sprayed her on track
peace
Old 10-03-2006, 09:03 PM
Camaro99SS's Avatar
I was honestly thinking the trap speed would be higher then that. What did you put down with the nitrous tune without spray? If I were you, I'd get a custom tune for n/a. I bet the tuner went a conservative route and is leaving alot left on the table considering you have arguably the best heads for a 346ci LS1 and a good size cam.
Jason
Old 10-03-2006, 09:19 PM
7 Second Club
Jason
What do you think the trap should be in a ~3650lb car
Old 10-03-2006, 09:32 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Does trap speed matter? No
ET wins races.
Old 10-04-2006, 01:19 AM
Kent1's Avatar
Your car is running fast for a 3650 lb car. The MPH is impressive and that is good driving for a 6 spd. Cheers
Old 10-04-2006, 06:39 AM
Moderator
JNorris's Avatar
Good numbers especially for the race weight. What rockers are you going with?
John
Old 10-04-2006, 09:56 AM
black_z's Avatar
Trap and ET are great for a hyd full weight 6-speed car.
Old 10-04-2006, 10:37 AM
99blancoSS's Avatar
Hey now dont argue with Phil about the tune. He the master right Phil. Just ask him he'll tell ya. Everyone elses numbers are bullshit right Phil?
Old 10-04-2006, 11:25 AM
7 Second Club
Great post. Lets see, we've got 3 passes on the car, I imagine it should be dialed in by now. Thanks for the intelligent post.
Old 10-04-2006, 11:49 AM
PREDATOR-Z's Avatar
The numbers are up to par. I went 11.5 but with a 123.53 mph trap (same weight)
My ET was shy due to my tranny slipping 2>3rd but mph is there.
good times Phil
Old 10-04-2006, 12:14 PM
99blancoSS's Avatar
I dont care if your gay Phil, parade all you want. My comment is directed towards you and not the car and you know it. Your the master tuner! You told me so in another post.
