Low numbers after heads/cam install
Old 09-30-2006, 03:27 AM
dixonk's Avatar
Default Low numbers after heads/cam install
I just put a set of patriot 243 heads and a thunder racing 594 lift with 226 duration and 112 LSA. Other mods include SLP lid, Smooth Bellow, Kooks Long Tube Headers. Before the swap I ran a 330 HP dyno and now I am only getting 333 HP. It is sending codes for engine misfire and I've also changed the O2 Sensors, TPS, and Map sensors already after it sent those codes but did not change anything! Any help kind of dissapointed on this was realling wanting to break the 400 barrier.
Old 09-30-2006, 03:47 AM
98slowt/a's Avatar
that is really bad. i would be pissed as hell!! good luck tracking your problem
Old 09-30-2006, 04:04 AM
35th SS's Avatar
a gain of 3hp.I would be really pissed.
Old 09-30-2006, 04:15 AM
dixonk's Avatar
Not only that but my torque dropped 10 ft/lbs.
Old 09-30-2006, 04:23 AM
N4cer's Avatar
What did your tuner say?
Old 09-30-2006, 05:06 AM
dixonk's Avatar
First it showed MAP Sensor Failure, O2 Sensor Sensor Failure, TPS Failure, Engine Misfire (Critical Performance) and a couple of U codes not to knowledgeable about that. I live in Kuwait so there's really no one inclined on this.
Old 09-30-2006, 09:46 AM
66deuce's Avatar
well,there's obviously a problem somewhere..who did the install?what length pushrods?did you degree the cam?could be a number of things causing problems.
