f13 piston to valve - confused here
Old 10-04-2006, 12:47 PM
frijolee's Avatar
Default f13 piston to valve - confused here
I checked my piston to valve clearance with my Futral F13 114lsa cam last night (checker springs and feeler gauges). I was a bit surprised to see I had only 0.065 on intake and a more than needed 0.130 on exhaust. My first thought was that I had the timing a tooth off but I checked that about a dozen times and conviced myself it's right.
After a bit of research it looks like I SHOULD be seeing 0.080 and 0.110 which would be perfect. Reference:
https://ls1tech.com/forums/generation-iii-internal-engine/452790-ptv-clearance-experts.html
I'm running ported lq9 heads, not decked that I know of.
I know the stock F13/F14 cams are supposed to have 4 degrees of advance ground in but I assumed that was included in the 0.080 and 0.110 above. What the hell's going on?!?
Old 10-04-2006, 12:59 PM
PREDATOR-Z's Avatar
Bigger valves?
Old 10-04-2006, 01:00 PM
Xtnct00WS6's Avatar
I'm just curious how you came to ur numbers using feeler gauges?
This is the way I was instructed to check PTV clearance:
https://ls1tech.com/forums/generation-iii-internal-engine/515456-ptv-measurement.html
Old 10-04-2006, 01:44 PM
frijolee's Avatar
Originally Posted by PREDATOR-Z
Bigger valves?
1.60 and 2.02. That might be something but it doesn't explain why exhaust is more than expected. I even checked two cylinders just to be sure.
https://ls1tech.com/forums/showthread.php?t=515456
Same here, except the only difference was that I used a stack of feeler gauges to measure between the end of the valve and tip of the stock (though rebuilt) rocker. Then I measured the stack with a set of calipers.
Quick Reply: f13 piston to valve - confused here
