3/8" Pushrod Question with ETP 215 Heads
Old 10-05-2006, 12:43 AM
jimmyz80's Avatar
Default 3/8" Pushrod Question with ETP 215 Heads
What's the deal with running 3/8" pushrods on ETP heads? I'm having some weird issues with my setup in the higher RPM range (in another thread here), and I want to swap in some stiffer and slightly longer pushrods. My existing 5/16" pushrods nearly touch the pushrod bores in the head. Will 3/8" pushrods even fit? I'm using stock rockers on the ETP rocker stand.
Old 10-05-2006, 05:00 AM
vettenuts's Avatar
Have you considered tapered pushrods?
Old 10-05-2006, 05:47 AM
beardWS6's Avatar
Have you called Cary at ET? Talk with him, he will get you on the right track!
Old 10-05-2006, 05:01 PM
pianoprodigy's Avatar
I got the ones that Andy @ A&A recommended. They were expensive.
Old 10-05-2006, 08:47 PM
02ZOh6's Avatar
I have 5/16" hardened/doublewall also and mine almost touch too. I'm not sure if we can go any bigger. No dyno yet either so I don't know if I have the patented dip after 6k.
Old 10-05-2006, 08:59 PM
mr2guru's Avatar
I noticed that too. The pushrod holes are offset to the centerline of the lifter on every other one so 3/8 pushrods will be real close. But there are at least 3 people I know running 3/8 pushrods with ET heads. I would assume they work. Mine are on order regardless.
If they touch or don't fit I guess I will have my machine shop bore out the hole ever so slightly.
Just the last 1/2" is tapered to 5'16". Point is moot.
