Will this Cam Clear with 59cc LS6 Heads
Old 10-05-2006, 02:22 PM
bluecamaroz28's Avatar
Default Will this Cam Clear with 59cc LS6 Heads
Will there be a PTV issue using this camshaft with these heads. Does the pistons need to be notched.
Comp Cams 54-448-11, 238/240 .605/.609 @112
Patriot Performance GM LS6 Series Stage II 59cc
Using stock head gasket.
What will be SCR and DCR?
What Pushrod length should be used?
Old 10-05-2006, 05:06 PM
pianoprodigy's Avatar
Assuming the cam is ground straight up and that this is on a stock bottom end...
I get 11.05:1 SCR and 8.0:1 DCR.
Using a Cometic .040 (recommended for proper quench): 11.4:1 and 8.24:1 DCR.
With 2 degrees of advance ground in (more typical), you'll get about .2 more on the DCR.
Not sure on the flycut, measure and see, but I'm guessing that you will have to fly cut.
Old 10-05-2006, 06:08 PM
allngn_c5's Avatar
You beat me to the flycutting comment. Rent the tool, you are going to need it.
Old 10-05-2006, 08:43 PM
Any word on Pushrods length?
