What To Do Heads Or Cam
Old 10-07-2006, 12:56 AM
fstls1camaro's Avatar
Default What To Do Heads Or Cam
would you go bigger cam or heads if you had a 222 224 cam at 370 horsepower.explain what heads or cam.
Old 10-07-2006, 02:15 AM
Kent1's Avatar
You could get a new set of heads to go with the present cam if you like it. For the cam you have, your horsepower is excellent. Also, a good set of heads will increase your horsepower by an average of 40. AFR's are a good set of heads. I personally purchased a set of TSP's terminator heads with a MS3 cam-most of my driving is done at the track. If most of your driving is done on street for a DD, I think a new set of heads is your ticket and hardly no tunning would be required. Hope this helps and good luck.
Old 10-07-2006, 01:21 PM
ssbodyman's Avatar
Do the heads, definetly. Then if you not happy with the cam, you can just change it out with little exspense and alot less work.
Old 10-07-2006, 07:04 PM
pdd
pdd's Avatar
i would do the heads and see if you like the results with the tr224
Old 10-07-2006, 07:41 PM
02TransAm/Batmobile's Avatar
i dunno, . explain more about your setup, what you like and don't like, . . . for a cam like that, heads are recommended but not a necessity, . . the bigger you go on a cam the more the need for a set of heads to utilize the power. If you're pretty happy with that cam i would jus do some heads - maybe TSP's LS6 CNC ported ones, . . you don't need that expensive of heads for a low to mid size cam, . . . you should be over 400 hp and have great low-to-mid torque, . . .
hope that helps
Old 10-10-2006, 06:54 PM
Brian2001SS's Avatar
I did heads with my tr224 and after a stong tune got some very nice results. So like mentioned above, do heads with the oppurtunity of going bigger with the cam.
