How much power would be lost with 6,000rpm shift points?
Old 10-08-2006, 03:06 PM
Cerebrex's Avatar
Default How much power would be lost with 6,000rpm shift points?
Just wondering how much power I would be losing having my shift points set to 6k on my heads/cam ls1? I'm doing this to drag out the life of the stock 4l60e. Thanks for the help!
Old 10-08-2006, 03:10 PM
ohsofast's Avatar
That is a great question b/c I plan on doing the same thing.
Old 10-08-2006, 04:12 PM
BriancWS6's Avatar
It all depends on what your peaking at. Some of the cams will peak alot lower than others.
Old 10-08-2006, 04:50 PM
Cerebrex's Avatar
the TSP Torquer II is what I'm running with their TSP CNC LS6 heads (stage 1).
Old 10-08-2006, 06:34 PM
c5chines's Avatar
Default 6K shift???
The C5 Vette with a LS1 and a 4L60 has a 4K shift point stock. Works for me. Chuck.
Old 10-10-2006, 09:25 AM
TeEnAgE pHeNoM's Avatar
Huh?
Old 10-10-2006, 09:47 AM
Cerebrex's Avatar
I was wondering the same
Old 10-10-2006, 10:05 AM
black_z's Avatar
I shift my bolton car @6200. Your leaving a lot on the table.
Old 10-11-2006, 12:33 AM
BriancWS6's Avatar
Yeah you are definately losing power by shifting that early. I don't see why your afraid to shift higher. On my previous car which was an a4, I shifted the little 225/225 cam at 6500 with the limiter set to 6800. I had no problems.
That cam should peak somewhere around 6200-6400ish depending on what LSA you have it on. Do you have a graph I could look at? The general rule of thumb for an auto would be to have it shift ~400 rpms higher than where your peak hp occurs. I would have it shifting at 6500-6600 without even seeing the graph.
Old 10-11-2006, 09:11 AM
Cerebrex's Avatar
The graph is on the first page of the dyno section in the thread about the torquer v3 made by Brian @ Texas-Speed. I changed to the v3, but my goal remains the same. I want to put the shift points at 6k so that the stock transmission lasts longer. Power doesn't kill them, high RPM's do.
Old 10-11-2006, 10:01 AM
slow trap's Avatar
i'm with brian, anything shy of 6500-6700 you will be losing quite a bit.peak hp will be atleast 6300-6400 and shifting that early you are dropping way below your optimum rpm range.only one real way to tell = hit the strip with 6500-6700 shift points atleast once and see.
Quick Reply: How much power would be lost with 6,000rpm shift points?
