hmmmm...i think i may have spun a rod bearing...help please:)
Old 10-10-2006, 07:08 PM
half-n-half's Avatar
Default hmmmm...i think i may have spun a rod bearing...help please:)
ok guys well i was driviing my car, and it always wanted to die out on me, i figured it was tuning due to the cam, and occaisionally i heard like a creaking sound....i thought it was a loose harmonic balancer...
well as of saturday night my oil pressure dropped drastically...like to 25psi at idle and then up from there during throttle...
i thought this was odd..it was a little low on oil, so i added some and then i drove home...it was still dieing out and stuff but i took it easy and let it sit til today...
today i fired it up, and cold oil presure was at 45 or so so i thought all was well...
but as it warmed up i started to get a knock, the car always wanted to die out..at idle and the oil pressure went back down to around 25 or so...
i was scared shitless it was knocking and te car wouldnt idle for **** so i could hear where the sound was coming from....i babied t home and just pulled the whole front end of the engine off and i am not really seeing anything wrong
the valves all look good and the front end looks good...
did i spin a bearing?
What is the best way to know, check?
Thanks
Louie
btw i havent really gotten on my car too much to start this i have been babying it a lot..
Old 10-10-2006, 07:48 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I can't tell you for sure, but it doesn't sound good for you
Old 10-10-2006, 07:50 PM
well there werent any shaving in the oil, and the cam came out and looks real clean...
no one has any advice...or even looks
haha
Old 10-10-2006, 07:59 PM
lol i know right...
figures happens with the weather starts to suck and i cant ride my bike too...my luck!
Any one know if it is possible to pull the pan and check with the engine still in the car?
Old 10-10-2006, 08:04 PM
SLO98Z's Avatar
Do you have anything to cut the filter in half? Have you made any recent changes at all?
strokedls1's Avatar
What advice can someone give that can't hear the sound or check out the car. Nothing to say except tear it down and see what is going on.
Old 10-10-2006, 08:11 PM
jaymans99ss's Avatar
The samething happend to me and it was a spun rod bearing. not saying that is what is worng with yours. Time to get strocked. haha
Old 10-10-2006, 08:12 PM
no recent changes at all...
and as far as advice just curious if things like
low oil pressure is related to a spun rod bearing, or a bad oil pump
if there is any way for a bad oil pump to cause this kind of noise...
etc...
or what about a lifter, wiill a lifter make a knocking type noise?
will a bearing that is on the brink start out with a someone squealing sound? what about an oil pump?
Thanks guys.
Old 10-10-2006, 08:13 PM
it really sucks, and i am thinking the same...i need a car...haha
i dont mind if it takes a week or so, but damn...
another prob i have is getting the damn engine out, any way to do this with the engine in the car?
Thanks again...
Louie
Old 10-10-2006, 08:29 PM
well i just cut the filter..anything i should check for, shavings i will assume...and there isnt really much in there...
i mean nothing to make my be like...ohh ****, ok that sucks...
Old 10-10-2006, 08:46 PM
SLO98Z's Avatar
Sure... A spun bearing will usually cause a drop in pressure and knock. Some have zero pressure. A bad pump could cause a knock due to lack of lubrication of course. Lifters usually tap, but could sound like a knock if a few were collapsed. I was driving the **** out of a guys built 5.0 vert and collapsed all the lifters on one side of the motor. It knocked it's *** of, but still pulled hard.
Old 10-10-2006, 08:48 PM
DONAIMIAN's Avatar
If it makes you feel any better my oil pump died at idle this past sunday.
Old 10-10-2006, 08:52 PM
Closed ex-Sponsor Account
sho-me speed's Avatar
Check fo a collapsed lifet if you oil and oil filter look fine.
Old 10-10-2006, 08:59 PM
hmmm here is teh newest info...on the bottome of the crank snout it looks a little gouged up...i dunno if that is from the harmonic balancer, or what...
filter looks fine, but i think there may be little shavings in the pan i am going to try to get a magnet in there...
i guess the only real thing to do is pull the engine, or replace teh pump and pray for good news when i put it all back together...
then if i get bad news..i pull and rebuild...
Old 10-10-2006, 11:10 PM
DaddySS's Avatar
Do a search on replacing the rod bolts, should be info on dropping the pan in the car and pulling the caps.
Old 10-11-2006, 10:26 AM
awesome, i hope that there is...
Old 10-11-2006, 12:03 PM
seems like the search function is down...is it?
if not anyone mind searching it for me..it is giving me an error everytime i search...
Old 10-11-2006, 01:11 PM
dedge's Avatar
There was a soundclip of a car with spun bearing of here somewhere. Use search and look for spun bearing. Anyway my car sounded exactlly like the car on the sound clip and thats what my trouble was. A spun bearing.
Old 10-11-2006, 01:20 PM
yup...i think i have just decided that is what my problem is...haha
i need to learn how to change these bearing with engine in the car...
Old 10-11-2006, 03:31 PM
gun5l1ng3r's Avatar
You are going to have to take the crank out, so you might as well rebuild the whole motor because there are a lot of surfaces that need to be lubricated while running. In your case, you lost oil pressure and who knows how much damage was done to the crank, rod bearings, cam bearings, cam surface... It all needs to be spec'd out in order for this motor to last for another 100,00K miles...
Quick Reply: hmmmm...i think i may have spun a rod bearing...help please:)
