Patriot Cam Base Circle Size
Old 10-10-2006, 07:34 PM
Psychopjv's Avatar
Default Patriot Cam Base Circle Size
as the title states i need to know that. i'm checking for pushrod length and i checked it twice with a comp cams checker 1st time was 7.425 on the checker. did it again to reassure myself and came up with 7.450. now add in preload and this seems like alot of pushrod for the 232/230 .580/.580 on a 110 i have. any help is greatly appreciated.
Old 10-11-2006, 03:15 AM
PREDATOR-Z's Avatar
Make sure the checker is on the base circle lobe when you are checking.
> tighten rocker with p-rod checker a little loose (short) to 22lbs
>unscrew the checker and make sure it fits in the rocker cup till you have 0 lash
> 0 lash is no wigly motion on the rocker (but not tight)
> take the rocker off and read your checker
> add .080 preload to that and voila, that is your p-rod length.
P-rods are made in .025 increaments so choose the closest one on the lower side to your measurement.
Expl: if you measured 7.440 with preload factored in, then 7.425 should be your choice.
Old 10-12-2006, 06:56 PM
Psychopjv's Avatar
good luck unscrewing the checker while it's tightened down in there......no room. still would like to know the base circle i know somebody has to have a patriot cam and can help a brotha out. though not like it matters much since it snowed 3 inches here today.
