too much oil press?
too much oil press?
is it bad to have too much oil press? i started to pay attention to my oil press gauge since ive been keeping up with the "should i really switch to GC/amsoil/royal purple/redline/walmart brand/anything but m1" threads. i havent noticed any "sewing machine noise", and ive never had oil consumption problems. it gets m1 full synth 10w-30 every 4k miles. i just noticed since ive been paying attention in the last week or so that my press guage reads 48-ish at idle, 2k rpms cruising reads around 60-ish, 4k rpms cruising reads around 73-ish, and on a hard pull all the way up the tach its nothing for it to peg the gauge...any thoughts? im just trying to make sure somethings not amiss before i have bigger problems...
thanks
-cam
thanks
-cam
There is a point where you'd spin a bearing as the oil is moving too quickly past the bearings to lubricate them. But that point wouldn't be reached until well after 100psi. The 03/04 Cobra 4.6's run very high pressure, a little higher than your car. If a mechanical guage does indeed verify your high oil pressure readings, the clearances must be pretty tight. If it were my motor, I'd just run a regular 30wt synthetic like Mobil 1 5w30 year round.
Jason
Jason
Here are Oil articles by an MD/Biochemist/Car Guy that might change some peoples mind. 0W-30 for me.
http://63.240.161.99/motoroil/
the new LS4 oil pump is better then the ls6 ported or not and its only 60 bucks from fred beans...
75psi - cold start
55psi - hot hot idle
75psi - WOT
65psi - cruise anything over 1200rpm
75psi - cold start
75psi - WOT
75psi - cold start
75psi - WOT
and this is with chevron 5w-30 mind you
75psi - cold start
75psi - WOT
