Cleaning the engine up?
I am going to be doing my heads in amonth and just doing some research on types of cleaners for the block itself. I see that people are having good results with a ice scrapper getting the bigger stuff off and not scratching the block. What is a good liquid to use and what is not good to use.
I also need to clean up my ls6 intake as it has oil all over the inside. I am taking my time doing all of this and want to get as much off as possible. Just trying to see what people have had good luck with here.
Originally Posted by 98REDZ
Easy Off Over Cleaner, problem solved. let it sit on for a bit, take the block to the carwash and its cleaner than ever.
There are several engine degreasers out there just for this purpose. Look at your local auto parts store. If it's that dirty anyways, it might be a good idea to pre-wash before you do the tear-down. The only thing worse than bloody knuckles are greasy-bloody knuckles.
purple power, and a pressure washer, works wonders on aluminum, but you cant let it sit b/c its an acid and it will etch aluminum, spray it on and let it sit for about 2-3 sec's and blast away, but it works awsome.
