Mahle piston valve reliefs
Old 10-12-2006, 04:59 PM
code4's Avatar
Default Mahle piston valve reliefs
I am building my budget engine for boost & I am using -4cc mahle pistons. Is it a good idea to round the sharp edges on the valve reliefs to deter knock? Has anyone done this?
Thanks,
Old 10-12-2006, 05:43 PM
chriswtx's Avatar
yes, I do this. But arn't the Mahle pistons coated? If they are I wouldn't do it...
Old 10-12-2006, 05:46 PM
code4's Avatar
I don't know? They don't look coated to me?
Old 10-12-2006, 05:55 PM
chriswtx's Avatar
If it was a power pak piston its coated...
Mahle's PowerPak piston assemblies include forged pistons, piston rings, pins, and wire locks--all in one race-proven package. The pistons are hand-deburred, and then coated with dry phosphate to protect against ring micro-welding and pin galling during initial startup. For additional performance, Mahle added its proprietary Grafal anti-friction coating to the piston skirts. Low drag rings, steel pins, and round wire locks complete the Mahle PowerPak package.
http://www.mahlemotorsports.com/C125.../mmscat03c.pdf
Old 10-12-2006, 06:02 PM
code4's Avatar
Thanks, I bought these 2nd hand but they are new so I wasn't sure. I'll check into this.
Quick Reply: Mahle piston valve reliefs
