DCR calculation PLEASE
Old 10-12-2006, 06:21 PM
lilbuddy1587's Avatar
Default DCR calculation PLEASE
Adv. Duration 289/297
.200 164/169
110 LSA
108 ICL
-4cc pistons, .040 gaskets, 62cc heads.
Thanks!
Old 10-12-2006, 07:17 PM
Beast96Z's Avatar
Assuming stock cubes, 10.8 SCR and 8.03 DCR. You can use the calculator you know. http://www.kb-silvolite.com/calc.php?action=comp
Old 10-12-2006, 07:34 PM
Irocss85's Avatar
thats cool. does anyone have all that info on a stock engine? then I can just adj. the things I have changed like the int. closing point, head port volume.
chris
Old 10-12-2006, 07:43 PM
8banger's Avatar
Nice...not giving away your duration/lift @ .050". i was going to go with one of their customs grinds, till I found mine.
Old 10-13-2006, 02:56 AM
bad95killer's Avatar
Please give me the exact Input buddy cause i had some rediculous numbers based on lilbuddy1587 specs. with explination....!!
peace
Old 10-13-2006, 09:23 AM
Mcduffys's Avatar
.200 164/169
110 LSA
108 ICL
Thanks!
Being that i know this is a 382. I got 11.4 SCR and 8.5 DCR. I calculated with 3.9inch bore and 4inch stroke.
Beast96Z, Can you check my calculations ?
Old 10-13-2006, 10:46 AM
oange ss's Avatar
i got 11.77 and 8.8..assumin deck height -.005
Old 10-13-2006, 11:23 AM
Mcduffys's Avatar
why a deck height of -.005?
i went with .007.... maybe im not understanding the deck height.
Old 10-13-2006, 11:52 AM
oange ss's Avatar
"-" above block deck,"+" below block deck, in calculations anyway....stock is any where from -.005 to -.008
Old 10-13-2006, 04:15 PM
Irocss85's Avatar
guys, trying to figure this out for myself. how bout clueing a fella in on all the stock specs nec. to figure this out? Im still waiting on my cam card so I cant just put that info on here for you to figure out for me. as for cyl. CC, are they looking for combustion chamber size? or runner size? IM goin to assume chamber size right? whats the stock MLS head gasket bore diam? 4.0? thanks.
chris
Old 10-13-2006, 10:37 PM
Beast96Z's Avatar
With the calculator I posted, I get 11:8 SCR and 8:85 DCR. If the piston comes above the deck, you have to enter the - number.
chris
Not sure on the exact stock specs, if search worked, you could probally find it. You need to know your combustion chamber volume. 62cc's in this guys case. You'll also need the formula for calculating IVC at .006". It's not on your cam card. That formula is : Advertised duration divided by 2, plus your ICL, minus 180. That will give you the IVC for the last blank. The site says just add 15 to .050", but that is horrendusly off, and basically a guess.
