Pro Mod I-beam rod torque
I torqued mine to 75ft-lbs. They had already been stretched when they were installed the first time so there is no way of knowing what the proper torque is. I heard 70-75 ft-lbs if torquing after stretched is about right. You don't have to get new bolts after stretching. When checking/setting bearing clearances, the bolt bolts are tightened and loosened many times. 810 miles on the motor and my rods are still in one piece.
