.010 too much for factory sleeves?
Old 10-17-2006, 06:58 PM
52172's Avatar
Default .010 too much for factory sleeves?
Just wanting some opinions on whether or not .010 off the factory sleeves would weaken them too much for 650 rwhp? According to a shop near me that is what they believe is needed to be removed to get them right? Then they say I would need to resleeve my block instead so it would be strong enough to support the 650rwhp?
Old 10-17-2006, 08:03 PM
ABeasst's Avatar
I had always heard no more than .007 over. thats what we did with mine.
Old 10-17-2006, 08:31 PM
2000slpss's Avatar
when texas speed did my bock they went .010 over stock and i specifically told them i was going to spray at least 250 on it with a heads cam setup. om not sure if thats above the "limit" of overbore though
Old 10-18-2006, 02:09 AM
Jeff@TotalPerformanceEng's Avatar
On an LS1/LS6 block, .010 is the last bore you can go to before you would re-sleeve or go with a new block.
You will be just fine.
Old 10-18-2006, 07:48 AM
52172's Avatar
thanks guys. I will talk to the shop about it.
